Pre-Configured Foobars!!!!
Ok, enough of you kids whined that I went ahead and configured foobar for several different cards....these 3 versions of foobar should satisfy everyone's needs. And no, I have not tested them.
Insructions:
-download and install foobar 2k 0.8.2 from http://foobar2000.blogsite.org/
-If you use an Audigy 1 card, or something else that is 10k2 based (as most are) and uses 16bit, download http://oregonstate.edu/~moritaty/Foo...20(Audigy).rar Extract that and replace the installed foobar directory.
-If you use an Audigy 2 card (and it's variants), or something else that resamples and uses 24bit (as many do), download http://oregonstate.edu/~moritaty/Foo...0(audigy2).rar Extract that and replace the installed foobar directory.
-If you use some other card that does not resample internally, and accepts 32bit, download http://oregonstate.edu/~moritaty/Foo...resampling.rar and extract that, replacing your installed foobar directory.
This "preconfigured" version includes all of the necessary plugins, all configured for optimum sound. This also is preconfigured with the currently highest rated formatting string.
Other things you may want to do:
-restrict the database to only your music dirs (preferences > album list)
-install foo_looks:
check out http://www.btinternet.com/~sean.m.kelly/foo_looks/, and follow the guide at http://www.btinternet.com/%7esean.m....s/install.htm. (skins are at http://www.btinternet.com/~sean.m.ke...ks/gallery.htm)
No more whining!
"can i listen live, to you babble iam bored"
-Tweaker
Just to verify-
The non Audigy version includes/uses the ASIO plugin?
My current rig
Dell Dimension 8200:
Dell 2000FP
P4 2.53 Ghz, 1G PC800, 120 GB WDSE, XFX 6600GT (dual DVI!)
Terratec DMX6Fire LT/Zemo-dded EMU 0404, Altec Lansing ADA 995s/Pimeta+HD580s/A900s
Win XP Pro/Office Pro
MX1000/MS Wireless Optical Desktop Pro keyboard
Belkin Universal UPS 1200VA
ATI Fanboy
ahhh nice job Zemo!!!
.:|:. Thermaltake Xaser II A5000A Case
.:|:. OCZ PowerStream 470W PSU
.:|:. Chaintech VNF3-250 nForce3 250
.:|:. AMD64 3000+ 2.0Ghz @ 2410Mhz
.:|:. Zalman CNPS7000-Cu Copper HSF
.:|:. OCZ 1GB PC-3500 EB Platinum Edition @ 240Mhz 3-2-2-10 (2.9V)
.:|:. ATI Radeon x800 Pro 256MB @ 530Mhz/560Mhz
.:|:. Creative Audigy 2 ZS
.:|:. Klipsch Promedia 5.1 Ultras
3DMark01 - 25617
Join Fix-it.org Forums!
Thanks much Zemo ! i spread the word in other forums!
*Mac Pro 2.66 Quadcore Xeon
*3GB fbdimm
*8800 GT Superclock evga
*2407WFP-HC
*810GB HDD total space
*AUDIO|Pioneer VSX-815|Klipsch Ultra Sub|rears|Infinity C250|
|Boston Acoustics CR67|
|Ath-A900|Penguin Amp Ultra
*SONY 40XBR4 40" HDTV
the links to all the files at loodi.com on the guide are dead. can't find them on google. either
No, ASIO achieves the same result as kernal streaming, but by using much more CPU time. The only time I've had to use ASIO is when I configured the computer at the studio I used to work at....card resampled internally to 192kHz.
I know!
I'll fix that, but these preconfigured foobar's don't need those extra files.
I'm guessing the other thread was closed for cross-posting
Close my thread will you?! *Shakes fist violently*
That's what my songs look like now, I'd like it to say Artist - Album - Title - Length (kinda like the Title Bar)
well, it's doing that because of the specific formatting set that's in there right now...you COULD code your own formatting, or steal one from http://pelit.koillismaa.fi/fb2k/index.php...but then people would be whining some more....
ok, dangit, I'm gonna redo those pre-installed ones to use a new formatting set...
-Tweaker
Title formatting
in the interim, you can go to Preferences...Display...Title Formatting and select the Playlist tab. On the lower right side there is a button that says "reset", above the "Help" button. (Not "reset all") This will reconfig the playlist to use FB2K's default playlist, which is similar to the title formatting you referred to.
Btw, helloz to everyone!
In Case of Bose, Break Glass.
Naughty direct hyperlink
Zemo, you should know better than to directlink to a file on a website. I change the filename with every version posted. Shame on yuo!
What?! What'd I do?! Those pre-configed foobars are on my own site!
BTW, welcome to sharky's Chastity!
-Tweaker
Zemo, you're a @#$@)(%&ing genius
EDIT: Zemo, I also hate you. You finally got the midrange right, to a point that I want to throw these speakers out the window....but of course, I don't really want to spend the grand or two necessary to buy a much better system.
My current rig
Dell 2000FP
You're directlinking to http://mysite.verizon.net/vze559m7/, aka http://foobar2000.blogsite.org. tsk tsk What happens to your links when I update the next version?
ah, I see! Will fix immediately!
That's your site? nice work!
-Tweaker
OK, that reset works, thanks Chastity. Boy, you just hopped right in here didn't ya
Welcome.
