How in the HECK do I do this?
Results 1 to 11 of 11
Thread: How in the HECK do I do this?
    Tiger Shark DeadSanta's Avatar
    Jul 2002
    Denver, CO
    How in the world can I route the AC cord from my Eheim>out of my case>into a wall socket>and still be able to close my side panel? I'm really lost and I wanna do it without having to drill a big, ugly hole somewhere!
    Any ideas?
    DeadSanta
    Hammerhead Shark Trunks's Avatar
    Sep 2002
    Fremont, California
    Can't you run it out the back of your case? Just take some of the PCI slot covers off, get some cutters and vut the aluminum strip out and run it through that.
    Intel Core i5 2500k @ 4.5Ghz, MSI P67A-C43, Antec Kuhler 920, 16GB (4x4GB) Patriot G2 DDR3 1600, Sapphire Reference R9 290x, Samsung 840 Series 120GB SSD, Seagate 1TB HDD, Antec 650 Earthwatts, Antec 300, Corsair Vengeance K95 + M90
    Late 2009 21.5" iMac - 3.06ghz C2D, NVidia 9400m, 4gb RAM, 500gb Hard Drive, Magic Mouse
    Steam ID - Entrical85
    PSN ID - Entrical
    Currently playing: MLB 14: The Show
    remember me? number1sixerfan's Avatar
    Sep 2002
    Ohio
    In order to do that, you will have to cut a part of the cord(the end part that goes in the socket) because its too big to go through the little pci slots. But that's what I did. I cut a part off of each side of the end so that it would fit through.
    Jul 2002
    Denver, CO
    Cut it like this?:
    How would I go about cutting it? It's pretty dang hard.
    DeadSanta
    Jul 2002
    Denver, CO
    Yay! Why can't they just @$#^& make the cords the way I want them!?
    DeadSanta
    Sep 2002
    Ohio
    Are you ok?lol I don't know how you would go about cutting that cord. It looks a lot different from the standard cord I have.
    Sep 2002
    Ohio
    And you know you can always get a rely switch. But then you have to cut through your case.
    Jul 2002
    Denver, CO
    I'm fine. Just a little pissed off at myself 'cause I knew I was gonna cut up my finger. I can't figure out what to do with the cord. Bleh.
    I think I'll just cut a divider of aluminum running between the pci slot to run it through.
    DeadSanta
    Catfish O.o's Avatar
    Apr 2003
    could just lop off the end of the cord and then
    put it back together when u get it through
    the back o the case
    Tiger Shark Slinks's Avatar
    Jensen Beach, FL
    u have three options to do this without cutting your case up.. 1 u can open your power supply and solder the wire to the off on switch on the back of your power supply or, option number 2 they make a relay that fits in to a pci slot it dosent actually do anything electricly through the pci slot with the motherboard it just uses the pci slot for support. relay
    or, 3 do what the person suggested above
    Desktop:
    Lian-Li Case A64 3500+ 90nm 4x512 MB Kingston HyperX DDR500 2X 10,000 RPM SATA WD Raptors Raid 0 2X 6800 GT's (SLI) 600W Enermax 21" G220fb Viewsonic Soundblaster Audigy 2 ZS Klipsch 5.1 ProMedia Ultras/Sennheiser 595's
    Notebook:
    Sager 8790 17" widescree P4 3.0c 512 MB ddr400 mobile 9700 pro 256 MB
    File Server:
    2X AMD 2000+ MP ATI 9200 128MB 1GB Corsair XMS pc3200 LSI Raid 5 600GB
    EQ2 Char. Mongol lvl 60 Ranger : Server Innothule : Guild Bidean Caer
    Cleveland, Ohio
