Walmart Sat. Stands *pic*
To anyone who has wondered how these are, I just picked them up and they're pretty good. The base actually reminds me of the one from Klipsch, but you decide.
Construction wise, it's build of cast iron and feels very study. There are a number of bracket mounts included as well. Color is in a gunmetal, grayish tone. Product link:
http://www.walmart.com/catalog/produ...A96890%3A78837
$35CND tax included.
I use these for my front channels, and highly recommend them. Quality is comparable to the omnimounts I use for the rears.
Klipsch Promedia Ultra 5.1
M-audio Revolution 7.1 sound card
Sennheiser PX-200 headphones
Got them for the rear sats on my Ultras. $30 US
Edit: You need to run those wires up through the pole of the stands!
I actually need to run the wires up mine too. I need to stop being so lazy.
I don’t really like my onmimouts, the bracket is too small for the sat, so it allows like 25 degrees of play, I can just turn it left and right, it’s really bad. So I’m going to fabricate some metal brackets and post some pics when I get some time.
Resident Audiophile
Geez are yours supposed to be tilted that far down? Mine sit pretty flush with the base of the stand, although the rubber washers allow for some play.
Zoom-Zoom!
That's an excellent deal for $35CDN.
I got the same ones a while back when i lived in Orlando, FL. I thought they were a great deal and they are built very well, i love em too!
Alpha Dir of The Coolers Guild
System 1:
Athlon XP 2400+ Mobile 243x10.5 (everyday use)
SLK-900a w/92mm Tornado
Radeon 9700pro 405/355
DFI Infinity Ultra
2x256mb Twinmos PC3700
80GB Segate 7200 8MB Cache
Klipsch Promedia 4.1's
Radeon 9700Pro - 19975 3dmark Compare
System 2:
Athlon XP 2600+ 166x13
AX-7 w/80mm 50cfm Sunon
ATI Radeon 8500LE
Epox 8RDA v1.1
2x256MB Kingston HyperX PC3000
Looking to buy: Retail HSF off of a BFG 5900nu
I'm gonna grab a pair sometime during the weekends. It looks very similar to that Creative stand. The mounting whole is exactly what I'm looking for.
XELA!
Athlon XP2400+ @ 2343Mhz (11x213)
SLK 947U w/92mm Tornado w/Nexus 205
Abit NF7-S Revision 2.0
OCZ PC-3200 Platinum 2x512MB @ 426Mhz
ATI Radeon X850XT
WD 60GB | WD 40GB | WD 160GB SATA
Antec Plusview 1000AMG | Thermaltake PurePower 420W Active PFC
Windows XP Pro SP2
Creative Sound Blaster Audigy 2 ZS | Creative MegaWorks 550 THX
Laptop 1: Dell XPS M1710 | T2500 | 2GB RAM | GeForce Go 7900 GTX | Hitachi 100GB 7200RPM
Laptop 2: MacBook | T7400 | 1GB RAM | 120GB
Let me know how it goes. Might get it for my Gigaworks if it works for your Megaworks.
Sure
XELA!
ATI Radeon X850XT
Windows XP Pro SP2
Some play? Cast iron feels unforgiving. I also have Logitech, not Klipsch so the mounting holes be be at different degrees.
Chomp Chomp
um, yeah, it's not supposed to tilt down like that...
turns out the klipsch stands are exactly the same as the walmart stands.
c2d e6600, gigabyte ga-965p-ds3 3.3, x1950pro, 3gb ddr2 800
The bastards at Klipsch probably rebadged it. Probably not. Who really knows?
I'll look into fixing the tilt tommorrow. I just need a heavy hammer and some eye goggles. don't want sparks or shards of it popping in my eye.
Man, don't you sleep? Chicago, home of deep house baby!
