Bad motherboard?????
Results 1 to 6 of 6
Thread: Bad motherboard?????
Hybrid View
    Reef Shark sparker11's Avatar
    Question Bad motherboard?????
    Help please! Do I have ANOTHER bad board?!?!
    I have an Abit board but can't save any of the settings besides loading the optimized defaults!
    What is happening??
    Abit KR7A-133
    Athalon 1800+
    512 DDR RAM
    3.5 Drive
    Hercules GeForce2 Pro Video card.
    If I set say the time and reboot the computer just HANNGS!
    If I load w/optimized values it boots up.
    I've reset the CMOS using the jumper and removing the battery a few times ... any ideas .. HEEELP!
    Thanks.
    Mako Shark Motoman's Avatar
    Wit yo momma.
    Re: Bad motherboard?????
    What is happening??
    Abit KR7A-133
    Athalon 1800+
    512 DDR RAM
    3.5 Drive
    Thanks.
    Hmmm...have you tried replacing these components with others, to see if there's some odd kind of conflict?
    At any rate, I'd definitely try flashing the BIOS to the latest version. If that doesn't work, you might have a goofy CMOS chip...
    REMEMBER THE WORLD TRADE CENTER!!!
    My WTC Memorial Website (and other stuff)
    - I used to be a SETI top 0.2% user! - Modded Computers
    Main gaming rig: Athlon 64 3000+, ECS 755-A2, GeForce 6800 128Mb, Philips Acoustic Edge, 2Gb Corsair XMS PC3200, 120Gb Hard Drive, etc.
    Creative Labs = poop
    Should I still try flashing it even though it's the latest version???
    Grrr ... what a pain ...
    Dam! This is my second motherboard .. the first was COMPLETELY dead .. this one won't let me change any of the settings.
    I tried the latest BIOS .. but I have the same problem.
    Anyone else??!?! This is crazy!
    DON'T GET THIS MBOARD AND A EVERCASE E4252 CASE! WOW ... THANK'S TO EVERCASE FOR RESPONDING TO MY EMAIL ... ABIT .. NO COMMENT!
    THANK YOU FOR YOUR ORDERING OF THE EVERCASE'S PRODUCTS.
    THE CASE ECE4252 IS DESIGNED BY THE ATX FORM FACTOR STANDARD, BUT WE FOUND
    THAT SOME M/BS, I.E. ABIT'S KR7A-133 M/B, DOES NOT ABIDE BY THE
    STANDARD(ABIT'S OTHER M/BS FOLLOWED THE ATX STANDARD EXCEPT AFEW OF THEM, I
    WONDER WHY?, SO THE STAND OFF POSITION ON THE THIRD LOW ARE MISMATCH. TO
    AVOIDE THE SHORTING PROBLEM, YOU CAN SIMPLE USE A PLASTIC TAPE TO COVER THE
    M/B TRY BOSS TO INSULATE.
    SHOULD YOU HAVE ANY QUESTION, PLEASE DO NOT HESITATE TO CONTACT ME.
    BEST REGARDS,
    MARK LIN
    EVERCASE USA INC.
    TEL408)894-9003 EXT 110
    FAX408)894-9007
    EMAIL:[email protected]
    WWW.EVERCASE.COM
    Mako Shark ZhaoYun's Avatar
    Jan 2002
    Corellia
    Dude that sux, but it explains why so many people are having shorting probs with the Abit KR7A mobo.
    ~Knight of the OC Crusaders~
    ~Sigma Dir of the Cooler's Guild~
    I'm still saving up to build a new rig... While everyone else has already joined the darkside.
